atc 200 engine in a 200x frame
Old Jun 26, 2000 | 12:20 AM
bigmanm's Avatar
I got a good deal on a mint 200x fram with everything but the engine. I put my atc 200 motor in it and everything is working great but one thing. If any one knows, the little metal and rubber intake tube between the engine cylinder and carb. well this piece is from the 200 motor and it will not let the carb fit in there. The back shock is in the way. Does the 200x motor have a different intake hose. or dose this motor just sit in there different. All the bolt holes lined up good.
Old Jun 28, 2000 | 04:08 PM
clpalmer's Avatar
If I remember correctly, yes it does. In fact, the intake for the 83-85 200x is different than the one for the 86-87 200x. I'm not sure if one of the versions of the 200x intake will fit the 200 engine or not.
Old Jul 2, 2000 | 03:55 AM
Oldbear53's Avatar
I just did the same conversion and I don't remember anything about the intake being off.May be I did use a 200X intake.But I know the break {rear} was a easy fab job.
Old Jul 10, 2000 | 07:53 PM
ThreeWheelio's Avatar
I also have done the same conversion.
I had to get the little black peice off of a 200X motor so it would fit, it was the only extra piece that I needed.
metal249
Jul 28, 2015 09:35 AM
Bell21
Jul 28, 2015 06:52 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
RedRancher
Jul 10, 2015 06:36 PM
bikedad3
Jul 2, 2015 02:15 AM
