changing needle clip position
Old Jan 4, 2004 | 01:28 PM
javex's Avatar
Default changing needle clip position
i have my stock carb apart and can't get the needle out of that black thingy. i tryed to push the needle out but it doesn't seem to want to go and i don't want to force it. how do i get it out to change the clip position? i have read some old posts i am confused on how to make it richer. i move the clip positon towards the sharp end of the needle or towards the not sharp, rear end?
Old Jan 4, 2004 | 01:37 PM
buttfungus's Avatar
Stock carb diagram..
Look here, you pull the needle out of the top of the slide. It's held in with a plastic plug/with small o-ring. Use needle nose pliers and gently pull it out. But watch for flying parts! There's a small spring, clip, and small washers so be careful.
Old Jan 4, 2004 | 02:34 PM
javex's Avatar
its diifficult to get the clip out of the grooves in the needle. is there a special tool to help?
Old Jan 4, 2004 | 06:46 PM
RoughRider01's Avatar
Just use a set of pliers to get that off there, itll come right off
Old Jan 4, 2004 | 06:47 PM
bigben's Avatar
A good pair of needle nose pliers are worth their weight in gold for that job.
That little spring is a NIGHTMARE to find in a full garage. [img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 4, 2004 | 06:48 PM
My spring went for a ride too when i first pulled the needle out, good thing the DJ kit gives you a spare.
Old Jan 4, 2004 | 06:56 PM
PUSHINTHELIMIT's Avatar
You're telling me! I lost it the first time I rejetted it over a year ago and didn't even notice I had it missing in my carb untill yesterday when I put my stock needle back in! Boy was I PISSED to find out I been riding it for over a year with the needle bouncing up and down about an 1/8 of an inch. Good thing the DJ kit had an extra spring..... I guess I have ONE good thing to say about the DJ kit.
Old Jan 4, 2004 | 07:02 PM
bigben's Avatar
I got a used DJ kit, and it didn't come with that spring. I was reading through the directions before I put the kit in, and noticed there was supposed to be an extra. I thought to myself, "why on earth do they send an extra when they don't even tell you to replace it?" I got my answer when that little thing came shooting out of there.
I'm glad to know I'm not the only one to lose that spring, though it sounds like I may be the only one that found it again. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 4, 2004 | 07:09 PM
javex's Avatar
done... finally got that clip off.. my ds came from the dealer in the 4th clip position. i moved it down (towards the sharp end) into the 5th clip position from the top of the needle. to richen the pilot u turn that screw out? i turned out about 4 turns. my quad runs about the same, no significant change in power i noticed and good throttle response. however, my headers still glow red guys but not too bright glow. u can only see at night with your lights off.
Old Jan 4, 2004 | 10:06 PM
Slowride's Avatar
javex,
I push the clip off against my finger versus pulling it off. I use hemostats or a screwdriver to push the clip off. I have lost less clips this way.
jbt
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Aug 5, 2015 05:55 PM
ghost civic
Jul 30, 2015 04:09 PM
TLC
Jul 25, 2015 02:24 AM
ghost civic
Jul 20, 2015 12:36 PM
