The best tire under 18 lbs
Old Jun 27, 2000 | 05:50 PM
Hondapride's Avatar
I wanna get new tires for my Recon but I don't want them to weigh anymore than the origional stock tires. Which is around 14 to 18 lb (I think)
Can anyone make some suggestions?????
www.geocities.com/hondapride_98
Old Jun 28, 2000 | 01:55 PM
KawasakiKid's Avatar
Well, problem with that is, usually more agressive a tire means more rubber, which means more weight.
Also take into consideration sizes. Obviously larger tires will weigh more.
In regards to which tire, that would depend on the type of riding you do. If you like the swamps, mud, and muck I like the Blackwater tire.
I just got off the phone with JL Products 800-233-2637 they said that the 27x9x12 Blackwaters weigh 24lbs a piece! Phew!
Well, for gnarly tread, usually you have to sacrifice weight. For example, if I want 44" boggers on my GMC Truck I'll definitely have to sacrifice weight compared to a 36" tire.
Hope this helps.
Old Jun 28, 2000 | 07:14 PM
snowshark's Avatar
Try the Sur Traks, they are very good mud tires, I think they weight about 19 pounds apiece. Call Rocky mountain ATV & ask them.
Old Jun 29, 2000 | 11:02 PM
Hondapride's Avatar
Thanks I will have to check that out
Old Jul 1, 2000 | 03:35 AM
HONDAHOLICX's Avatar
25 in jackels weigh lik 16 pounds
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
