clutch cover replacment?
Old Jan 21, 2004 | 01:24 PM
speedydog5's Avatar
Default clutch cover replacment?
my brother has a 1993 350 4x4 and the clutch cover on front warped and ground a big hole in it is there a different cover I could use on it from a newer machine that will fit, it seems his cover is pretty thin, and is it possible the back cover may be warped, I would hate to put on a new front cover and the same thing happen since the stealer wants 120.00 for it[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 21, 2004 | 01:59 PM
CED's Avatar
CED
Try partsland.com you may be able to cross the #'s over to different years.
Old Jan 21, 2004 | 02:14 PM
baxy's Avatar
check ebay for a used clutch
any one off of an polaris atv will work except the EBS model you just have to put your weights and spring into the replacement to calibrate it properly
Old Jan 21, 2004 | 02:17 PM
baxy's Avatar
iff you meant the plastic cover I seen a couple of those as well I think they are interchangable too
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2455638519
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2454465344
try these links out
Old Jan 21, 2004 | 06:35 PM
NascarFan's Avatar
There is a new style out that is larger and less likely to rub. I replaced mine along with the inner cover. There are more screw holes and a drain plug on the newer style. I would think you would need to replace them together. Much improved cover. I think there are 2 basic covers. 1 for 4 stroke and 1 for 2 stroke. Check with your dealer to be sure.
Old Jan 22, 2004 | 12:16 AM
fishslab's Avatar
I would almost gaurenty that the back is warped too. I know it can be pricey, but do them both.
Cole Hadden
Jun 15, 2025 09:05 AM
clsharky
Jul 13, 2015 02:07 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
