Porting intake ?
Old Jan 22, 2004 | 12:29 AM
arnold's Avatar
Default Porting intake ?
I have a ? what kind of tool do you need to get the top bolt out of the intake i know it is a allen wrench but i am stumpted, i just can't seem to get anything in there i took the motor mount off but it still wont fit, also the bolt for the motor mount is wearing the aluminum on the head from vibrations what can i do to fix that. if sombody can help I it sounds like a stupid ?............[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 22, 2004 | 12:40 AM
saint650's Avatar
i have a set of long head allen sockets with a ball on the end. the ball is cut like the allen head so it will grip on an angle. the whole thing is like 6 inches long. i dont really remember what size but i think it was a 6mm.
Old Jan 22, 2004 | 12:49 AM
CountryJoeGlass's Avatar
If you still can't get the top center allan head bolt off, but you got the other outer ones off you can turn the intake conter clock wise to loosen it up & then try again. make sure you have a ball end allen wrench. Been there & done that, it sucked. Just remember to take your time & ask questions, thats what I did & saved me from buying a new intake!
Old Jan 22, 2004 | 12:56 AM
BlackHawk's Avatar
I used a ball end allen wrench, and used some vice grips to give me a little more leveredge when turning the allen key. It made the whole situation a 'non-issue.'
Old Jan 22, 2004 | 01:03 AM
I forgot that! Well said blackhawk!
Old Jan 22, 2004 | 01:23 AM
DuneMe's Avatar
5mm Allen
Solution to wearing upper motor mount. . . don't use it! We cut mine out completely when we put the FCR's on. Even with the 760 it isn't needed.
If you are removing the head / cylinder you may want to grind away a little on the upper motor mount and the mount on the head. This will allow you to remove the head without removing any of the lower motor mounts.
Old Jan 22, 2004 | 01:42 AM
arnold's Avatar
Thanx guy's I don't know what i would do if there wasn't a site like this somtimes its the simple things things that stump you, the best luck to everybody in the new year.........[img]i/expressions/face-icon-small-smile.gif[/img]
franklyme
Oct 21, 2016 07:18 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
