wolverine timing
Old Jan 25, 2004 | 03:59 PM
Itsallgravy's Avatar
Default wolverine timing
i was just wondering how to reset the timing on my wolverine
i had the engine bored .040 over
i lost my manual and my friend is putting it together and we arent sure how to set it
also i was wondering if a warrior would have the same timing as the wolverine
Old Jan 25, 2004 | 04:16 PM
JakalWarrior's Avatar
What are you talking about timing? you cant touch the ignition timing. If you mean cam timing, the mark on the cam should meet or come real close to the mark on the head when the crank is at TDC.
Old Jan 25, 2004 | 09:07 PM
95Wolverine's Avatar
In addition to the previous post, there should be a "T" mark on the flywheel. This mark is visable with the timing plug in the sidecase removed. Once the "T" is aligned with the mark in the hole, the crank is truely at TDC. Now, you can line up the cam with the mark on the head.
Good Luck and hope this helps.
Ride On.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
