wolverine timing
i was just wondering how to reset the timing on my wolverine
i had the engine bored .040 over
i lost my manual and my friend is putting it together and we arent sure how to set it
also i was wondering if a warrior would have the same timing as the wolverine
In addition to the previous post, there should be a "T" mark on the flywheel. This mark is visable with the timing plug in the sidecase removed. Once the "T" is aligned with the mark in the hole, the crank is truely at TDC. Now, you can line up the cam with the mark on the head.
Good Luck and hope this helps.
Ride On.
Ride On.
