WIRING
Old Jan 25, 2004 | 10:34 PM
VEGAS650's Avatar
Default WIRING
As most of you know the Sandpig has been apart for about 8 months.
I took alot of the electrical stuff apart, to clean. Also I am no longer running a tach.
Problem, and this is for the older DS's cause my 03 is different. I have a red wire that is in the same loom as the ignition switch that I don't know what goes to it.
Also, I have two red wires running together(really long) coming out of the main harness that look like they may never have been used, but I don't remember what I disconnected when I put the tach in.
I'm sure my dealer can answer these questions, but I'm sure they're sick of me by now.
Thanks, Al
Old Jan 26, 2004 | 07:26 AM
busmechanic's Avatar
Default WIRING
do any of them have a violet stripe? if not there are only three solid red wires on the diagram that I am looking at. one from magneto with a 25 amp fuse. one from starter to starter solinoid. and one from batt. to starter solinoid.
Old Jan 26, 2004 | 10:27 PM
VEGAS650's Avatar
Default WIRING
I think the two long red ones (one has an orange stripe) go to the fan/ temp sending unit on the right side.
I have different wires connected there cause I wanted to be able to turn the fan on manually with a switch.
I am going to look at some one elses DS Weds to get the ignition wires figured out.
I remember when I put the tach on 3 years ago that I had to switch some wires around.
Yes one of the other ones has a violet stripe.
Al
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
frostphase
Aug 19, 2015 07:11 PM
DeFox500
Jul 26, 2015 06:32 PM
