fan doesn't work!
Old Jan 26, 2004 | 12:13 AM
4504x4's Avatar
Default fan doesn't work!
2002 honda foreman es, anyway i went mudding and i went in some water that was too deep, it came up to the fender and the quad died on me, so we pulled it out, drain the exhaust, airbox, and carb. its running great now, but the overheat fan won't come on, any ideas?
Old Jan 26, 2004 | 12:50 AM
hondabuster's Avatar
Try hot wiring it, and see if it works. Then youll either find the fan is junk or you have a wiring/wetness problem. Check the fuses, it could have tried coming on, but shorted out because it was wet...might work again when it dries .
Old Jan 29, 2004 | 02:41 PM
Justforfunhonda's Avatar
I urge you to pick up the Service manual from Helm or your local dealer, it will tell you how to test what is wrong with it exactly, ie thermostat, fan motor, etc.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
sara durrant
Jul 6, 2015 05:32 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
