Anybody got an LT80 wiring diagram?
I'm installing lights and a new handle bar cluster from an E-Ton on an LT80. Does anyone have a wiring diagram for an LT80? It would make my life a little easier thanks.
I have one in my manual. If you get a manual it would give you all sorts of good info. Otherwise maybe just get a cluster of ebay . They go pretty cheap on there. Hope this helps .
John Cahoon
John Cahoon
To view info on how others installed a light on their LT-80s, surf:
http://forums.atv_source.com/viewtopic.php?t=1683
Note: Remove the "_" in the above, then surf the site.
Hope this helps...
Thanks for the replies, but I am trying something a little different. The E-Ton handle bar cluster includes two extra switches the LT80's doesn't. It has a switch for a horn and lights. I had already mounted a horn on it so I'll tie that in no problem. Same for the lights. I would like a copy of the wiring diagram so I can Save myself some wire chasing and having to pull plastic off just to figure out what goes were. I would really apreciate it if anyone was willing to e-mail me a copy of the diagram. Thanks!!!!!!
Fishslab
Fishslab
I just finished photocopying the entire manual from the dealer. PM me and I'll fax you the wiring diagram, or maybe I can figure out how to scan it at work and email it as an attachment. i don't think there was any difference in wiring between my '93 and your '95.If you need any other specs, let me know.
Chocobamofo
Jul 10, 2015 07:46 PM
