Engine Temp?
Old Jan 26, 2004 | 01:32 PM
jstaguy24's Avatar
Default Engine Temp?
Im Installing a thermometer on my quad so I can monitor Engine temp when racing up Sand Mountain. Anyone know what temp a 2 stroke motor should run. It is a Honda Cr500 motor but im sure most two strokes should run close to the same temp. Any info would be great
thanks
Old Jan 26, 2004 | 08:21 PM
bansheeesmoker's Avatar
where did you put it, rad hose or what?
Old Jan 26, 2004 | 08:41 PM
Trasher's Avatar
A friend of mine put a sensor on the head pipe of his Pilot. You wouldn't believe how quickly it would jump up or down. You could be in a bowl and it would hit about 1150-1200 and crest the top and cruz which would result in temps of about 700.
Old Jan 27, 2004 | 11:18 AM
jstaguy24's Avatar
I plan on putting it on the radiator hose or somewhere on the radiator. Wherever I can get the best reading. i havent had time to install it yet
Old Jan 27, 2004 | 11:32 AM
Trasher's Avatar
placing it on the hose that goes to the radiator, just after it passes through the engine would get you the best readings.
Old Jan 28, 2004 | 01:58 AM
Doctorturbo's Avatar
GOT BOOST!
If you run it hard I would put an EGT and a CHT on it also.
Old Jan 28, 2004 | 11:13 AM
jstaguy24's Avatar
this may be a dumb question but what is a EGT and CHT? never heard of them
Old Jan 28, 2004 | 11:32 AM
Trasher's Avatar
Exhaust Gas temp
Cylinder head temp
Old Jan 28, 2004 | 11:33 AM
jstaguy24's Avatar
Ok got ya
Old Jan 28, 2004 | 05:43 PM
It's etg exahust temp gauge, it's probly the best way to go.tell's by temp if your rich or lean so you dont lose your top end also can use it for a temp gauge too. by knowing your exhaust temp you save your motor before somthing bad happens, and esr makes a in line rad hose temp gauge for 80$. I'm gonna run both.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
DeFox500
Jul 26, 2015 06:32 PM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
