Suzuki lt50a Help with running
Old Jan 26, 2004 | 11:40 PM
Smitty1's Avatar
Default Suzuki lt50a Help with running
Hello I did some of the mods for this bike. Removed restrictors both intake and exhaust. Ported the intake a little bit . Removed the stacked jet. and drilled holes in air cover. The bike now runs great and has enough power for my son. However after a while it just dies and I cant get it started till it cools. Does anybody know if I now Have to Run a cooler plug it has the stock (4) in it right now. or is it possible that it still is needing more fuel. This is only happening after about 45 minutes of riding after it cools it starts again but will only stay running for another 10-15 minutes. I also kept the stock 55 main in. The plug looks great to me it looks a little dry. Coco brown. If anyone can please help it would be appreciative. Mike
Old Jan 27, 2004 | 12:32 AM
MattFisher's Avatar
Start with a B5ES plug, the stock BP4ES is waaay hot.
With the airbox holes, you may be running lean at certain throttle positions, try raising the needle a notch. I also run the bike on prime only, using the on setting as off.
The stock exhaust port is so small that it's hard to jet the bike, though you may need to step up to a 60 main. I'd suggest using Motul 600 injector oil to keep the carbon build up to a minimum.
Old Jan 27, 2004 | 01:39 PM
Smitty1's Avatar
Thanks for your help I will switch plugs and try that different main. Then I will post results so someone else may benefit from my mistakes. Thanks Again Mike
neilbedwell
Nov 10, 2018 11:02 AM
Scott-Leigh
Jul 28, 2015 09:32 PM
sut3000
Jun 25, 2015 02:00 PM
Jun 3, 2015 01:40 PM
Dieseltrash
Jun 1, 2015 06:53 AM
