makin by tb look better
hey guys u can see what all i got done to it so far (no much) but when the weather gets warmer i want to paint some stuff to make it look better i was thinking painting the a-ams chrome and the rest of the floor boards red ( i didnt finish painting the rims in the pics ) ..and cutting the plastic for the exhaust down.. does those colors sound good and is there anything i could do
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter **** and a snake, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
My friend was in a similar situation you are now in, If you dont mind the extra work i would take off the front a-arms and get them powder coated what ever color you desire, you could also do your frame if you wanted along with you swingarm,
Just keep in mind if wieght is an issue chrome is not the way to go
good luck
good luck
I have seen kits to powder coat your own stuff. You can do the baking procees in your oven. Thought about doing the a-rms and the floorboards yellow, but the floorboards won't fit in the oven. Eastwood company
i think im going to give the red truck bed liner in a can a try on the a arms, swing arm and hubs as long as it isnt a dark red and if it is dark red im going to use some spray paint and keep the rest of the frame black and make the nerf bars as on this tb
click here...
but i got one prob on that pic he has a yellow tube for his crankcase intake and on the tbs it has a black tube box for the intake thats in the way for the air scoop so i was going to put one of those tubes on but do any of you know where it ends and would it even be a good idea or not to put one on and does it affect the h/p
click here...
