My aching back!
Old Jan 28, 2004 | 03:06 PM
Cammer's Avatar
Default My aching back!
Guys I think my rear spring needs to be softened up a bit. Do I need a special tool to adjust it? What is the easiest way and are there any watchouts?
Cam
Old Jan 28, 2004 | 07:37 PM
Cammer's Avatar
Bartlett,
Thanx for the info. Which you do you recommend to soften the ride? Shock adjust or lengthen the spring?
Old Jan 28, 2004 | 08:30 PM
busmechanic's Avatar
mine was adjusted to soft. [the spring] it ate the upper roller in short order. so watch that your chain will not be setting on the upper roller with you on the quad after lowering spring load. I raised mine until the chain was just off the upper roller with me on it. now it just hits when spring is compressed. the roller is lasting alot longer now. I ended up with about 3 1/2" of sag.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
