info on pulling flywheel ???
I took off the pullstarter assembly and am looking right at the flywheel. I have a gear type puller that threads 3 bolts into the flywheel and has a center bolt that pushes against the center bolt that goes through the flywheel. I put it on there and started turning the center it got real tight and didn't move it feels like somethin is going to break if I try turning it any harder. It seems like there is somethin else holding it but I dont see anything. can anyone help me?? ( guess it would be esier if I had a manual) LOL
If you do any heating, be careful, cause your stator is behing the flywheel. Some heating is o.k.. A very thin film of anti-sieze can be wiped on the crank before you re-install it.....just a film though.
GregM
Mar 6, 2018 06:53 AM
