info on pulling flywheel ???
Old Jan 31, 2004 | 10:39 PM
TooFastIsBarelyEnough's Avatar
Default info on pulling flywheel ???
I took off the pullstarter assembly and am looking right at the flywheel. I have a gear type puller that threads 3 bolts into the flywheel and has a center bolt that pushes against the center bolt that goes through the flywheel. I put it on there and started turning the center it got real tight and didn't move it feels like somethin is going to break if I try turning it any harder. It seems like there is somethin else holding it but I dont see anything. can anyone help me?? ( guess it would be esier if I had a manual) LOL
Old Jan 31, 2004 | 10:49 PM
badcompanyracing's Avatar
its really hard to get it off, we heated it with a torch and beat it a few times with a hammer and it still was hard to get off but it finally came.
Old Jan 31, 2004 | 11:05 PM
JEFF10049's Avatar
Tighten it up real good and then give the center bolt of the puller a good hit with a hammer should pop off.
Old Feb 1, 2004 | 01:55 AM
O.K. I got it (easy money) just tighten it until you think it is going to break and turn it another 1/4 of a turn and it will pop off into your hands. thanks for the info
Old Feb 1, 2004 | 02:09 AM
modquad's Avatar
If you do any heating, be careful, cause your stator is behing the flywheel. Some heating is o.k.. A very thin film of anti-sieze can be wiped on the crank before you re-install it.....just a film though.
Old Feb 1, 2004 | 11:46 AM
wgr's Avatar
wgr
If you are going to use heat on the flywheel, try a kettle full of boiling water poured on it,you risk damage useing a torch.
GregM
Mar 6, 2018 06:53 AM
SDR-II
Sep 29, 2015 01:06 AM
GearheadMOM
STOLEN
Aug 8, 2015 11:47 AM
kdg723
Jul 25, 2015 01:20 PM
ghost civic
Jul 15, 2015 10:48 PM
