magnum 425 clutch spring?
Old Feb 1, 2004 | 12:44 PM
Figgers's Avatar
Default magnum 425 clutch spring?
Hey all. My local dealer tells me that they do not recommend putting a stiffer clutch spring in my 425. They say that its not a good idea on a 4 stroke. I'm assuming that its because of the limited rpm compared to a 2 stroke. It looks to me like many of you have upgraded springs on your 4 strokes. What are your thoughts on this? Did you notice a performance gain? I was considering the white spring which is two up from the stock green/yellow. Thanks for any comments........
Old Feb 1, 2004 | 07:11 PM
ftwflh's Avatar
Telll your dealer to bite your but and get you a white primary spring.
Old Feb 1, 2004 | 09:30 PM
Figgers's Avatar
Thanks for the laugh. So it makes enough difference that its worth while? Did you notice much of a difference with yours flwflh? Thanks.....
Old Feb 1, 2004 | 09:36 PM
ftwflh's Avatar
It is the best $20 you will spend on it.
Old Feb 2, 2004 | 02:02 AM
JEFF10049's Avatar
Just do it. you will like it!
Jeff
Old Mar 23, 2007 | 09:44 AM
BuddyP's Avatar
What is the rate of the stock spring vs the white spring? I assume this is a Polaris white primary?
ghost civic
Jan 15, 2020 07:43 AM
brinkkl2000
Oct 16, 2015 11:08 AM
cdstang
Aug 31, 2015 07:52 AM
Dan Newberry
Aug 30, 2015 09:42 AM
coolguy420
Jul 10, 2015 01:17 AM
