wide 250ex
Old Feb 4, 2004 | 04:47 PM
Eric250EX's Avatar
Default wide 250ex
right now im working on gettin my quad alittle wider, i know theres back spacers but whats a legit website for them and for the front what a-arms would fit and whats a good website for them. I also heard people switching and rotating the front wheels so the air valve faces inside, i did that but the valve hits the brack rator and i like front breaks so i switched the wheels back.
so basically;
website for a-arms
website for rear wheel spacers
THANKS
Old Feb 4, 2004 | 05:19 PM
Eric250EX's Avatar
Default wide 250ex
help me pretty please with surgar on time etc.
Old Feb 4, 2004 | 05:29 PM
atvguy217's Avatar
Default wide 250ex
have you tried typing it in search?
Old Feb 4, 2004 | 11:36 PM
scosho's Avatar
Default wide 250ex
Dura-Blue makes 1.5 " spacers that will fit, I believe. If you want to reverse the rims, you have to drill a new valve hole on the original inside of the rim and plug the original valve hole on the outside. Then they will clear the rotors. Good luck.
Old Feb 5, 2004 | 12:06 AM
RedEX's Avatar
Default wide 250ex
Seems I've heard you can get a lot of "bump steer" with spacers... Any truth to that?
Old Feb 5, 2004 | 09:38 PM
Sandrider503's Avatar
Default wide 250ex
DuraBlue makes rear and front wheelspacers I hear they are the best on the market. Don't get the front ones though I hear they are not to good. they will mess with your handling alot. but rear ones are fine. For the front I recommend longer A arms. Hope this helps. You can get 2.5'' on the rear thats a total of 5'' in the rear that should be plenty for any quad.
Old Feb 6, 2004 | 07:20 PM
Ridinfolks's Avatar
Default wide 250ex
I have the Durablue spacers on my EX250 . . . 1.5" in the front and rear. Bought them at a parts shop called "Dycorp" in Anaheim, CA. I like it a lot better - haven't noticed anything different with the handling. Your post was the first I've heard about handling problems - yikes! I have heard that you shouldn't get spacers if you're going to be doing a lot of jumping though. I just wanted a little wider wheel base so I won't roll over as easy.
Old Feb 6, 2004 | 07:50 PM
Default wide 250ex
I have heard that the rear is good to widen but the front is not so good. You should do the A arms instead.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
highwayman
Sep 19, 2015 12:59 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
