Belt explosion\KEBC problem
Old Feb 8, 2004 | 09:51 AM
Davinator's Avatar
Default Belt explosion\KEBC problem
I smoked my belt pulling someone out of a mud hole and 3 days later at full speed the belt exploded into a bunch of small pieces and string. I dug out all the stuff and replaced the belt with P-700 belt. Now the problem, in high range everything works fine. In low range however, when I let off the gas I hear a grinding\clanking noise coming from the KEBC. Almost like gears stripping out. I may still have some junk in the spring assembly of the brake I’m taking it back down today to look at what I see. Any help is welcome.
03 P-650
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet
Nyroc Exhaust Mod
Primary Dalton Plain\white spring
Secondary EPI black spring
P-700 Belt
ITP 589's on C's
Warn 2500 winch
Headlight mod
Rear backup light
Old Feb 8, 2004 | 10:11 AM
sledgehammer650's Avatar
D its sounds like you have some string stuck in kebc lever inside your cover. If the motor gets in a bind it will make a noise trying to move. So make sure that everything around the lever/spring is clean.
Old Feb 8, 2004 | 11:24 AM
Nightryder888's Avatar
could need a shift linkage adjustment
Old Feb 8, 2004 | 11:54 AM
NovaKaw650's Avatar
If it's only in low range, that should rule out a KEBC problem. As Nightryder888 said, check out the shift linkage adjustment.
Old Feb 8, 2004 | 11:57 AM
Davinator's Avatar
Don't think it's linkage, it worked fine before the belt exploded. I took the cover off and it‘s not the KEBC it appears to be the belt itself. It's grabbing the primary clutch when you let off the gas. The added pressure from low range makes it grab, but high range works fine. I guess I don’t have the deflection correct. When I spin the belt into position it’s in spec. Any thoughts.
03 P-650
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet
Nyroc Exhaust Mod
P-700 Belt
ITP 589's on C's
Warn 2500 winch
Headlight mod
Rear backup light
Old Feb 8, 2004 | 12:03 PM
NovaKaw650's Avatar
You may have belt crud from the explosion packed inside the primary clutch. You might have to pull it off and dis-assemble it.
Old Feb 8, 2004 | 12:24 PM
Davinator's Avatar
The primary looks good. The secondary was loaded, but I had already cleaned it out when I replaced the belt. It’s almost like it’s getting to much grip on the primary and the teeth of the belt are jumping. There is some belt stuff on the side of the clutch, but not in the contact area. I guess I’ll try to clean off the residue. I would think that you couldn’t have to much grip, but that’s how it’s acting.
03 P-650
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet
Nyroc Exhaust Mod
P-700 Belt
ITP 589's on C's
Warn 2500 winch
Headlight mod
Rear backup light
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
trouttracker
Jul 20, 2015 11:54 AM
