something going on with the transmission
Old Feb 9, 2004 | 09:33 PM
bw99's Avatar
Default something going on with the transmission
I got a 400I 4x4 manual shift, 03, anyway the other day I was plowing snow and after it had ran awhile and was good and warm, when ever I would go from 1st to neutral then to reverse the shifter would not spring back up then it would set there in reverse and not move until I pushed back on the shifter to bring it back up. Well yesterday I was plowing and the same thing happend, after it got good and warmed up, when ever I wanted to go to neutral, I'd push the shifter down and it just stayed down....Hope this makes sense to somebody...thanks for the help!!
Old Feb 9, 2004 | 10:31 PM
tricat's Avatar
I have had this happen also, I realy don't have a fix for you but I can tell you that I removed my shifter, cleaned and sprayed a little lub on the shaft. It did seem to make a diffrence.
When the shifter is down, it is like having it in nutral. That is why your reverse did not work. Hope this helps.
Old Feb 10, 2004 | 07:31 PM
bw99's Avatar
It does help, I appreciate your reply. I was lucky enough to get the 2 year warranty when I bought my bike, so I'm going to take in into the shop on friday to have it checked out, I thought if anyone else had this problem or new what it might be I would be that much farther ahead when I called the dealer...once again I appreciate your reply..
Old Feb 10, 2004 | 08:40 PM
tricat's Avatar
Please keep us posted on your findings!!
Old Feb 10, 2004 | 08:54 PM
mountainclimber's Avatar
I had the same problem and I took off the shifter and luricated it with tri flow. It worked fine and it still does.
Old Feb 12, 2004 | 08:04 PM
Polaris500HO4x4's Avatar
mine seems to do this every winter yeah good lube that doesnt collect dirt works great
Old Feb 13, 2004 | 07:07 PM
bw99's Avatar
well, gotter checked out today, just needed a good loobin..thanks for all your input!!!
Old Feb 15, 2004 | 12:18 AM
tricat's Avatar
Thanks for keeping us posted bw99!
Old Feb 15, 2004 | 04:05 PM
tmffoster's Avatar
I also had the same problem with my shifter sticking. I talked to my dealer about it and he said the clutch needed adjusting. There is a plate on the right side of the engine that has to come off and then there are two screws to adjust. Your dealer can tell you how to adjust it. This took care of my problem.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
