400 EX valve adjustment
Old Feb 9, 2004 | 09:35 PM
RoostKing's Avatar
Default 400 EX valve adjustment
Guys have any tips/instructions on adjusting the valves on a 400 EX? Thanks!
Roostking...
Old Feb 10, 2004 | 04:19 AM
schwendi's Avatar
set to TDC of the compression stroke
pull tank and plastic, pull valve caps
insert feeler gauge
loosen locknut and adjust to spec with flat head screwdriver if they are out of spec
tighten locknut, re-check
put it back together and call it a day!
Old Feb 10, 2004 | 01:18 PM
KGB's Avatar
KGB
The only thing I wil add is to check the tolerance between the spring and rocker, not rocker and secondary rocker.
Old Feb 10, 2004 | 05:20 PM
hutchies's Avatar
Valve Adjustment Instructions
Best help I can give you.
Old Feb 11, 2004 | 11:15 AM
hutchies's Avatar
bump
Old Feb 11, 2004 | 03:25 PM
steadyfreddie's Avatar
Make sure you have not run the engine for 24 hours before the operation. VERY important.
Old Feb 11, 2004 | 04:15 PM
odysseyjunk's Avatar
dont stip the cap nuts on the head by trying to use an adjustable wrench....i think the size is 7/8, or whatever that is in metric sizes....oh, and it will probably still be noisy when you adjust the valves....i think its just a noisy engine
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
