bayou 185 help brakes
Assuming you took off the two lock nuts and the cover the drum should slide off the axle. It's probably corroded and dirty on the splines. Clean them as best you can.
Hope that helps.
Scott
www.atvworks.com
Hope that helps.
Scott
www.atvworks.com
I have the same problem. I ended up prying and banging it until it broke free but I also broke the backing plate. Be careful but they are tough. I am trying to find out if you can interchange parts now. I have found a backing plate for a 1997 Bayou but I don't know if it will fit on a 2001 Bayou. Good luck
oliveiracarlos
Sep 7, 2015 03:39 AM
