bayou 185 help brakes
Old Feb 9, 2004 | 09:52 PM
alpine8181's Avatar
Default bayou 185 help brakes
does anyone know how to remove rear drum??it wont move....i heated it banged it is it supposed to just slide off or spin off? thanks alpine
Old Feb 9, 2004 | 10:21 PM
ATVWorks's Avatar
Assuming you took off the two lock nuts and the cover the drum should slide off the axle. It's probably corroded and dirty on the splines. Clean them as best you can.
Hope that helps.
Scott
www.atvworks.com
Old Apr 1, 2007 | 04:38 PM
droptop66mustang's Avatar
I have the same problem. I ended up prying and banging it until it broke free but I also broke the backing plate. Be careful but they are tough. I am trying to find out if you can interchange parts now. I have found a backing plate for a 1997 Bayou but I don't know if it will fit on a 2001 Bayou. Good luck
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
rcappie4
Sep 9, 2015 07:04 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
