jets
Old Feb 11, 2004 | 08:39 PM
ineedtoride's Avatar
Default jets
can someone please explain to me what this is and how doing what to them affects what... pilot jets, main jets, rejetting, the whole thing... i am confused [img]i/expressions/face-icon-small-confused.gif[/img] thanks in advance!
Old Feb 11, 2004 | 08:47 PM
dragracer789's Avatar
Default jets
Jets is what controls how much gas gets into your cylinder. Pilot jets are what feeds your motor gas from the carb at idle- 1/4 throttle. The needle is what controls the mid range of your throttle, and the mian is what controls 3/4 and up of you throttle. In each of these little round things there is a hole that the gas will go threw. You want your motor to be crisp. Not to much air, and not to much gas, and this is hwo you control that. When you make a change to your bike that effects the air flow (pipe, filter, porting) you will need To usually re-jet with bigger jets because more air will be geting into your cylinder and you will have to get more gas into it at the same time to even it back out.
If you got any more questions dont be scared to ask
Old Feb 11, 2004 | 08:51 PM
AlphaRaptor660R's Avatar
Default jets
carb jetting
read this for more info...
Old Feb 12, 2004 | 09:39 AM
Shav0's Avatar
Default jets
When you jet your quad, How do you know what jet to change?
Old Feb 12, 2004 | 10:26 AM
sickmojave's Avatar
Default jets
Did you read the post above yours??? [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 12, 2004 | 10:45 AM
Shav0's Avatar
Default jets
doing it right now
thanks
Old Feb 12, 2004 | 11:17 AM
sickmojave's Avatar
Default jets
If you have questions when your done just ask and we will find the help you need.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 12, 2004 | 01:00 PM
Shav0's Avatar
Default jets
I read the article. How come you never hear of people changing the throttle valve cutaway. I am always hearing about the pilot, main, and the needle and i understand all of those now. Is the throttle valve just not as important or does minor mods, like pipe, filter, reeds, and other little gains not affect it?
Old Feb 12, 2004 | 03:47 PM
Slacker1bob's Avatar
Default jets
Throttle Valve?
Are you talking about the Slide?
Old Feb 12, 2004 | 04:06 PM
hondabuster's Avatar
Default jets
The reason most people dont change the cut away(slide), is because they are hard to come by, are realitvly expensive, and only effect 1/8 to 1/4 throttle. Most guys are holding the thumb open a bit further, than that.
