Black spring problems
Old Feb 12, 2004 | 12:16 AM
sirmill's Avatar
Default Black spring problems
What's up guys,
I need a little help. I installed a black spring with about 80 miles on my bike. It now has 432 miles and the wheelies are harder to come by. When I installed the spring, I already had the 27 outlaws on and I could feel the difference the black spring made. Is it time to check the deflection and tighten the belt? Thanks for any input.
Old Feb 12, 2004 | 01:15 AM
trailride's Avatar
Did you remove your sim or shims when you installed the black spring ? Other than that i would say time for a new belt for some reason.
Old Feb 12, 2004 | 12:08 PM
trx450's Avatar
Time to check/adjust belt tension. Inspect belt and pulleys for glazing. You'll most likely just need to adjust it.
Old Feb 12, 2004 | 12:44 PM
sirmill's Avatar
No, I didn't remove any shims when I installed spring. I guess I'll go on Nyroc's site for belt adjusting info. If belt and clutch are glazed, how do I solve the problem? Do I have to buy another belt? Thanks for the input.
Old Feb 12, 2004 | 11:58 PM
meangreenmudmachine's Avatar
I did almost the same thing as you and the same thing happened to me, instead of removing shims or checking deflection, I just bought the Prairie 360 belt, which is a little wider and of course it was new. All problems went away and I got the low end power back, plus gained a few extra mph on top end also because of wider belt. Just a thought?? Or you can always just check deflection and maybe remove some shims.
skinnyr6
Aug 25, 2023 02:18 AM
coolguy420
Jul 10, 2015 01:17 AM
Riding Gear
Jul 7, 2015 05:03 AM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
