110 octane in KFX700?
Old Feb 14, 2004 | 11:13 PM
KFXoNyoazz's Avatar
Default 110 octane in KFX700?
Will 110 octane hurt my Vforce700..the only mods I have is clutch kit and a FMF PowerCore 4 pipe/w header.i was wondering if its to much octane..and it if it would damge my engine.thanks for any help.
Old Feb 14, 2004 | 11:49 PM
MrVvrroomm's Avatar
It won't damage your engine, but it'll seriously deplete your wallet. It's a waste of money. If you haven't done any serious head work, you're pissing away your money. 92 octane is more than enough. I run 87 in mine.
Bruce
Old Feb 15, 2004 | 01:10 AM
MnFriesen's Avatar
If I remeber right...when you get to a higher octane and you do not need it you actually lose power...I remember reading it on here once and there was reasons given but I am not clear what they were exactly
Old Feb 15, 2004 | 01:17 AM
KFXoNyoazz's Avatar
Wel..octane makes a engine run better..it makes the fuel burn straiter and cleaner..The only reason I asked if it would harm it is because it gained alot of poer after i added the gas to it..thats all..thanks agian.
Old Feb 15, 2004 | 08:21 AM
MrVvrroomm's Avatar
Higher octane only makes a motor run better that's tuned or built for it. The higher the octane the slower the fuel burns. It has nothing to do with how "clean" you think it burns. The only thing you're doing is wasting money by using 110 octane fuel. You may have perceived that your motor had more power, but put it on a dyno and you've gained nothing. In fact, as stated above, you probably lost power.
One of the biggest wastes of money is people burning 92 octane gasoline in their Chevy (Ford, Dodge) pickups and thinking it has more power or keeps the motor cleaner. This is just brainwashing by the big oil companies. Your V-Force motor was built to run optimum on 87 octane fuel. Unless you're going to tear into the motor and mess with your head clearance you're pissing your money away.
Old Feb 15, 2004 | 12:42 PM
BT250racer's Avatar
a higher octane will burn slower while a lower octane will burn faster u half to use teh right octane-compression to get the most power using 110 octane just when u got a fmf pipe and clutch kit isnt going to get you anywhere except less on money teh only time u need to change your gas is when u do work to your engine.
1999 250 trail blazer
k&n filter DG exhaust for now
just to make it a lil lounder
titan 489 xts on the back
maxxis razors on the front
full skid plate,bash gaurd
rebuilt trans,D.I.D chain
pro amor belt,scott grips
the newer model tie rod ends
12 t front 36 t back sprokets
neon shifter ****, pro burner lights
stronger back caliper holder i made at a friends shop
cut front fenders with the floor boards removed
makin aluminum dimond plate ones
Old Feb 16, 2004 | 11:22 AM
KFXoNyoazz's Avatar
Thanks guys@@!
MikeyBoyesq
Sep 7, 2015 10:44 PM
Polaris-400
Aug 19, 2015 02:20 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
