Possible Clutch/Transmission Problem
Old Jul 5, 2000 | 03:33 PM
ScoobyDFW's Avatar
When I shift from neutral into first gear when at a complete stop, it appears to go in hard (hear and feel a noise) and sometimes the DS will move forward slightly as if the clutch was not pulled. I tried adjusting the clutch cable but the problem will not go away. I am wondering if this could be why I am seeing metal shavings on the oil drain plug.
Old Jul 5, 2000 | 03:51 PM
Tree Farmer's Avatar
Scooby, a little clutch drag isn't unusual; a result of slight warping of discs, perhaps; or even oil "squishing" between them. A respectful question: how many motorcycles and ATV's have you owned prior to your DS?
Tree Farmer
Old Jul 5, 2000 | 04:01 PM
ScoobyDFW's Avatar
I've had no manual clutch bikes. The service manual states not to use synthetic oil or it could throw your clutch calibration off. The dealers messed up when I bought the DS and installed synthetic oil. When I later changed the oil and went to non-synthetic I first noticed this problem. And I heard that you aren't suppossed to break-in a motor on synthetic oil.
Old Jul 5, 2000 | 04:41 PM
Arizona650's Avatar
It is also standard practice that once you do go synthetic after your break in oil change you can't go back-I don't know if this is affecting you as I have never tested this addage.
Old Jul 5, 2000 | 04:48 PM
ScoobyDFW's Avatar
I haven't had any oil leak problems.
Old Jul 5, 2000 | 08:37 PM
87_250R's Avatar
i thought you just were not to mix oil i could be wrong. i would never mix any brand oil togather.
Old Jul 5, 2000 | 09:07 PM
JamesDS650's Avatar
Well, during the break in it should not have the synthetic oil in it, but if it did, it did. The problem is that synthetics have a softener in them that cause the seals to expand if they are not used to the oil. It should not hurt it once you go back to the regular oil.
Old Jul 6, 2000 | 01:53 AM
YellaTerra's Avatar
It could be a possible problem or it could be characteristic. Mine does the same thing and has never had synthetic oil in it.
Yella Terra
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
