400&300 HELP REPLY
Old Feb 18, 2004 | 08:03 PM
EXPLORERATVER's Avatar
Default 400&300 HELP REPLY
I WOULD LIKE TO THANK EVERYONE WHO REPLY TO MY POST. TOOK MY WHEELERS APART TODAY, I FOUND EVERYTHING THAT I DIDN'T WANT TO FIND(IF THAT MAKES ANY SENSE). ON THE 300 THE SKIRT ON THE PISTON IS BROKE OFF. ON THE 400 A PIECE OF THE PISTON IS BROKE OFF, BETWEEN THE TOP OF THE PISTON AND THE TOP RING. THE CYLINDER IS SCORED IN THAT AREA. IF I HAVE IT BORED OVERSIZED IS THERE ANY THING ELSE I WOULD HAVE TO CHANGE? OVERSIZED .020 OR .040. WOULD I HAVE TO DO ANYTHING WITH THE HEAD?
1998 300 XPLORER 48" POLARIS PLOW
2001 400 XPLORER 2000 LB WARN WINCH
(BOTH BROKE!!!)
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Feb 19, 2004 | 10:19 AM
HAMMERINHANK's Avatar
Bummer Explorer, sounds like a bad week..
You need to make sure you dont have any pieces in the case or you will more than likely be in for more rebuilding. Have the cylinder bored to the least you can to save the bore for more boring down the road. Look to make sure the broken skirt didn't whomp a hole in the case somewhere. Any tell tale signs of leakage that was'nt happening before? Wiseco Pistons here comes Explorer...Get that foriegn debris out of there.
What caused all this explosive behavior anyhow Explorer... DUG
Old Feb 19, 2004 | 10:26 AM
xxxracerxxx's Avatar
damn those stock polaris pistons suck when i took mine out it had two big cracks now i use wiseco pistons
Old Feb 19, 2004 | 10:31 AM
Stock pistons in anything........BAD MEDICINE
-----------WISECO----------Ahhhhhhhhhh ...Heap Good Medicine
Njrider1230
Jul 29, 2023 05:16 AM
snake99
Sep 30, 2015 07:31 PM
awer1968
Sep 8, 2015 11:02 AM
Haakon
Aug 24, 2015 01:54 PM
randymack
Aug 24, 2015 05:47 AM
