Diesel HELP- ANY Diesel Guro
Old Feb 28, 2004 | 10:27 PM
2000IAWarrior's Avatar
Default Diesel HELP- ANY Diesel Guro
I got a 83 F-250 Diesel and well awhile ago the glow plugs burnted out. so just used ether to start it till i got all the parts.. figured new controller,relay, and plugs. well orgered all new parts finally about aweek ago.. after about 3 months.. got the relay,controoer and plugs from usdieselparts.com some of the best prices around i thought.. well today. finally installed everything. when to turned the key and well it started.. one of the first times w/o ether.. so put the air cleaner back on shut the hood figured good deal. opened the garage door turned the key. waited till the light went out.. and guess waht! the glow plugs all burned out.. so do any of you know how/why this happend again? to much volts?not enough.. this is driving me nuts.. just spend 200 for parts almost... and probly didnt need the controller or relay.. but probly cant return them.. just pisses me off how come the burned out again.. after 1 min lettin it idle. then shut it off. for about 8 or so.. and then turned again.. and not workin!! any help is appreciated.. what to look for or anything!!!
Old Feb 28, 2004 | 10:31 PM
Chilly's Avatar
I think the Ford uses a timer somewhere in the system to turn the plugs off after they heat up. My guess is the timer or controller isn't working right, which means the plugs were receiving power the whole time the key was on. They won't stand that for long, and will burn out. Also check the glow plug fuse, it may only be the fuse.
Old Feb 28, 2004 | 10:37 PM
we replaced everthing.. the controller and everying, checked the controller to make sure it was shuttin off.. it was workin properlly.. so know knows..
Old Feb 28, 2004 | 10:41 PM
Chilly's Avatar
Is yours a 12 or 24 volt system? I know some of the older trucks used a 12 volt system to run everything but the starting system, and the starter used 2 12 volt batteries in series. Is there any chance they may have sent you the wrong glow plugs?
Old Feb 28, 2004 | 10:44 PM
its a 12v system.. they are the correnct glow plugs.. it worked the first time.. and then burned them out... liek a short.. but idk how it could.. just tickin me off
Old Feb 28, 2004 | 10:48 PM
Chilly's Avatar
It sounds like whatever caused them to burn out the first time is still there. I take it the fuse is OK?
Old Feb 28, 2004 | 10:50 PM
i suppose toher wise they woulndt of gotten any power to them.. we tested them. and they are burned out
Old Mar 1, 2004 | 12:00 PM
TexasPsycho's Avatar
i had one a few years ago doing the same thing but can't remember what i did. it was something going on in the precombustion chamber? i'll try to remember and i'll talk to friend thats a diesel mech to se if he can jare my memory. sorry i can't answer it right off the top of my head. might also try some of the diesel forums on other web sites. ford powerstroke owners have a pretty good web site for that type of question.
Old Mar 1, 2004 | 12:03 PM
sorry forgot the web address?? www.thedieselstop.com hope it helps.
TXMinuteman
Oct 6, 2015 06:43 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
kwackermann
Jul 6, 2015 11:01 AM
binford
May 17, 2003 08:54 PM
quad_man
Sep 8, 2000 10:18 PM
