Foreman gearing for different years
Old Mar 1, 2004 | 07:25 PM
FlyLow's Avatar
Default Foreman gearing for different years
I have a '96 Foreman 400 and a '00 Foreman 450es. The '96 has 24X10-11 wheels on back (stock). The '00 has 25X10-12 wheels on back (stock). Is the gearing different for these two machines? If I go to 26" tires on both, will the '96 struggle with the tire change more than the '00 (not taking into account the engine size)?
Old Mar 1, 2004 | 07:56 PM
Chilly's Avatar
The 400 is geared somewhat lower than the 450, as far as I know. If you can find some info on the 450 to compare it with, here are the gear ratios for the 400, taken from a Clymer manual.
Primary reduction is 2.103
Secondary reduction is 2.100
Final reduction (differential ratio) is 3.153
1st 4.083:1
2nd 2.388:1
3rd 1.608:1
4th 1.178:1
5th 0.878:1
The literature on the 400 mentions ultra-low first gear for slow work and pulling, the other gears may be fairly close.
Old Mar 1, 2004 | 09:28 PM
FlyLow's Avatar
Those are the same as the 450. Thats good for me. Can you tell me what the Primary, secondary and final reductions are?
For the 450 they are:
Primary: 2.103
Secondary: 2.100
Final front: 3.153
Final rear: 3.153
Old Mar 1, 2004 | 09:48 PM
honda450es4x4's Avatar
the 400 has the same motor as the 450 it is just bord out to a 432cc/433cc size
Old Mar 2, 2004 | 08:22 PM
Chilly's Avatar
[quote]
Read carefully, I just did..lol
neilbedwell
Nov 10, 2018 11:02 AM
toonces
Jun 30, 2015 11:19 AM
Big600twin
Jun 10, 2015 03:01 PM
neilbedwell
May 31, 2015 11:11 AM
MrElussive
Oct 26, 2000 02:30 PM
