tree doc hows heelclicker?
Old Mar 2, 2004 | 12:53 AM
Bubs's Avatar
Default tree doc hows heelclicker?
i was wondering how the heelclicker clutch kit worked.did it give you big performance gains and if so how much?
Old Mar 2, 2004 | 01:48 AM
TreeDoc's Avatar
I'm liking it! Right now, because I'm mostly playing on the dunes, I have the orange spring in it and that gives me good engagement for this type of riding. I haven't had much chance to get it in the rocky, hilly terrain since I installed it but when I do I'll try the stock spring again as I think that will be better for slower, more technical riding.
BTW, I like it so much I'll be ordering another this week for my new 500HO that I brought home on Saturday!
Old Mar 5, 2004 | 11:33 AM
camoman's Avatar
Did you install the clutch kit your self? How hard was it?
Also, Did your Lights make a big dif?
Old Mar 5, 2004 | 02:15 PM
TreeDoc's Avatar
Yep...did the install myself. It was easy and took maybe 2 hours of my deliberatly slow and methodical approach. The instructions on the Heel Cliicker web site are great and they show photographs of each step for reference. When I do my 500HO, I'm confident that I could have it done accurately in around an hour or so. My spring change takes about 15-20 minutes with most of that involving the removal and reinstallation of the screws holding on the side cover.
Old Mar 5, 2004 | 03:44 PM
camoman's Avatar
Did you need any special tools to install??
I am looking for more bottom end torque and less belt slipage.. would the HC help my prob?
Old Mar 5, 2004 | 03:54 PM
700EFI's Avatar
Treedoc I see you did the light conversion to make all three lights work. What did you do?
Old Mar 5, 2004 | 04:24 PM
TreeDoc's Avatar
Yep...it'll do that for ya. Probably should try leaving the stock spring in after you do the clutch weight mod. Mine engaged right off of idle with that configuration. I have the orange spring in now because most of my riding has been done on the dunes where I need more rpm and speed. You'll want to do what I think most guys do and try all the springs to see the difference in performance but you will likely work between the stock and orange spring as yellow is way high engagement and I have heard is more for racing applications. ???
I forgot the lights question.....yeah, those lights are a real help at night in the dunes, being halogen they are a bright white/blue light and that makes the stock lights seem dim but it helps to have all 3 of those burning with that Mod.
I bouht the light mod off of one of the many that are available on ebaY. It's real simple to do. Though the parts aren't worth the money you pay, the finished product is. Someone around here had directions on how to do it yourself but I forget who. You might want to do a search and see what comes up.
Old Mar 5, 2004 | 04:36 PM
camoman's Avatar
What about tools? Anythign special needed to install?
thanks!
Old Mar 5, 2004 | 05:08 PM
TreeDoc's Avatar
Probably the most technical tool was a snap ring plier for the disassembly of the secondary clutch and another pair of hands to compress the clutch so you can do so. My wife's boney, girly, arms sufficed for the compression task! [img]i/expressions/face-icon-small-wink.gif[/img]
RedRancher
Oct 15, 2020 01:45 PM
Ramman1
Jun 16, 2016 09:07 PM
Desimation2k8
Jul 17, 2015 12:37 AM
JackTheKing
Jul 14, 2015 09:09 PM
black_thunder
Jul 9, 2015 05:58 PM
