skid plates
Old Mar 2, 2004 | 09:42 PM
alwayssomethin's Avatar
Default skid plates
i have a 04 scrambler 4x4. for it, and just in general, whats the deal with skid plates? the scrambler has plastic ones on the a arms and chassis, but nothing on the swing arm. is the swing arm something that should be considered getting a plate for? also, is the stock plastic good or is metal/aluminum better? id rather be safe than sorry, but it looks like you can spend a ton on skid plates and wanted to get some opinions. thanks
Old Mar 2, 2004 | 09:50 PM
BT250racer's Avatar
Default skid plates
well i toke the plastic one off and made a templet for it and made a aluminum one and as for the swing arm skid most ppl dont like it b/c it gives your less ground clearence about a inch and a half i think
PERFOMANCE
.25 over head,
K&N filter, DG exhaust ( for now)
12t 36t sprokets,
back--titan 489 xts front--maxxis razors,
shade perfomance trans D.I.D chain,
pro armor belt, newer model tie rod ends
PROTECTION
skid plate, bash gaurd,
stronger back caliper holder
LOOKS
scott grips, neon shifter, proburner lights,
cut fenders, removed floor boards ( makin aluminum
dimond plate ones), painted bumper,handler bars,rims
Old Mar 2, 2004 | 09:52 PM
BT250racer's Avatar
Default skid plates
and i forgot to say i was thinking about getting one b/c i broke 2 calipers holders but i made one outa steel and gave it a aluminum layer on the outside so it doesnt rust
Old Mar 2, 2004 | 10:00 PM
BigBadScrambler's Avatar
Default skid plates
The stock underbody skid plate is pretty tough. It would be really easy to make an aluminum one though. Most people (like myself) go without a swingarm skid, or end up removing theirs. The sprocket gaurd does its job really well. The skid will just get you hung up easier. The only skids that I feel are important are the front under the bumper and the a-arms, more importantly the cv boots gaurds. I could not find an aluminum gaurd (just steel) that gave me the protection that I wanted for the cv boots (front, rear, and under). SO I made a carboard template and bent and welded up some aluminum and made my own. Turned out really well.
Old Mar 3, 2004 | 12:40 AM
Needmoretoys's Avatar
Default skid plates
Hello,
I ride the woods most of the time and I personally wouldn't ride with out a swing arm guard. I've got enough scrapes and dings in my skid plates, that I feel I did the right thing putting aluminun skid plates underneath, that includes the A Arms, Engine, as well as the Swing Arm.
02 Scrambler 400X 4x4, Blue
03 Trail Blazer 400, Black
04 Trail Blazer 250, Red Special Edition
03 Trail Blazer, Freedom
03 Trail Blazer 250, Yellow
95 Explorer 400 4x4, Red
92 Trail Boss 250, Gray/Blue
Old Mar 3, 2004 | 01:59 AM
ScrambleMe's Avatar
Default skid plates
If you have any trails that you may use that have rocks, then I'd get a rear skid. The one from polaris is what I have. Yes you loose ground clearance. Origonally I lost about an inch following the instructions for installation. Then after I removed the spacer they give you, I think I ended up only loosing about 1/4 to 1/2".
#2 After tearing a cv boot with the factory small plastic protector, I got a set of Oxlite steel A-arm/ Cv joint protectors, Only necessary if you find yourself around branches/sticks. So yes if you ride anywhere but sand then you'll probably need these at least.
Have fun with the new Scrambler.
lonerider856
Oct 13, 2023 03:45 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
