250x engine oil leaks
Old Mar 3, 2004 | 09:36 PM
donnie250x's Avatar
Default 250x engine oil leaks
when i put a cam and valve springs and i put it back together i put gasket maker on it but that didn't work and it is leaking oil i was woundering if anyone has rebuilt a 250x engine and have it not leak oil and what did u do to do that
Old Apr 6, 2004 | 02:09 PM
crappycustoms's Avatar
Get a real gasket and try again, it will leak a little but that is because the gasket needs to be broken in, and form to the contour of the casing. Whatever it may be
Old Apr 6, 2004 | 03:23 PM
THEXOTIC1's Avatar
Where is it leaking? Most of the 250x 300ex leak at the rocker cover. Use Hondabond for sealing them
Old Apr 6, 2004 | 04:59 PM
reconbasher's Avatar
they dont make a gasket for it, i used honda bond on mine when i had it, it never leaked.
Old Apr 6, 2004 | 05:06 PM
drummerguy84's Avatar
mines doin that...im too scared to pull the rocker cover off..I might break somthing [img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 6, 2004 | 06:51 PM
there isnt anything to break on it, its basically idiot proof. take all the bolts out of it and clean both surfaces real good and apply hodabond to it and bolt it back up.
slowgsxr97
Mar 18, 2022 03:40 AM
Nondem
Feb 22, 2020 12:20 PM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
