Dynojet Tech reply
Old Mar 5, 2004 | 12:11 AM
Pistonman's Avatar
Default Dynojet Tech reply
I called DJ today, asked about jet sizes, airbox mods. He said DJ jets and Keihin jets are of different design and can't be compared . As far as airbox mods and jetting, he had no advise other than starting at their rec. settings for elevation, pipe and filter......
Old Mar 6, 2004 | 01:37 AM
Bigsaint's Avatar
That's interesting. I compared the DJ jets to the MK jet and it appeared to be smaller ( 146 DJ compared to a 130 MK). All I can add is to follow their advice if you use their kit. I just installed a Big Gun exhaust with a K+N ( lid removed) on the KFX400 and ignored thier suggestion of starting with the 150 main jet. I started with the 165MJ and ended up downsizing all the way back to the 150 for good performance. That's with their supplied needle with the clip at the 3rd position, 3.5 turns out on the fuel screw. Now it screams [img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 6, 2004 | 01:45 AM
Pistonman's Avatar
I guess I will start with their rec. sizes. I will be using a Muzzy's pipe ( they rec. the D.J. kit) K&N , O/W, and D.G. snorkle( the unknown) and read plugs. Will post results.
Old Mar 6, 2004 | 03:45 AM
zero60's Avatar
Piston, Hey. I am new to the group and just wanted to get you feedback on the Muzzy exhaust. On Tues. I will be doing the equal length Muzzy pipe along with a dynojet and twin-air element( wich doesn't look like much but supposedly flows better than the stock air filter sock) Have you been pleased with your exhaust? what results did you feel and what is you suggestion for what may be next power wise. What does a cdi unit do hp or torque wise? thanks Man....zero60
Old Mar 6, 2004 | 03:55 AM
vannatt's Avatar
Here's a chart that will help.
Kehin/Dynojet Equivalency chart
Kehien Jets -------- DJ Jets
Num / Thou. ------- Num / Thou.
92.5 / 0.035 ------- 92 / 0.035
95 / 0.036 ------- 94 / 0.036
97.5 / 0.037 ------- 96 / 0.037
100 / 0.038 ------- 98 / 0.038
102.5 / 0.039 ------- 100 / 0.039
105 / 0.040 ------- 102 / 0.040
107.5 / 0.041 ------- 104 / 0.041
110 / 0.042 ------- 106 / 0.042
112.5 / 0.043 ------- 108 / 0.043
115 / 0.044 ------- 110 / 0.044
117.5 / 0.045 ------- 112 / 0.045
120 / 0.046 ------- 114 / 0.046
122.5 / 0.047 ------- 116 / 0.047
125 / 0.048 ------- 118 / 0.048
127.5 / 0.049 ------- 120 / 0.049
130 / 0.050 ------- 122 / 0.050
132.5 / 0.051 ------- 124 / 0.051
135 / 0.052 ------- 126 / 0.052
137.5 / 0.053 ------- 128 / 0.053
140 / 0.054 ------- 130 / 0.054
142.5 / 0.055 ------- 132 / 0.055
145 / 0.056 ------- 134 / 0.056
147.5 / 0.057 ------- 136 / 0.057
150 / 0.058 ------- 138 / 0.058
152.5 / 0.059 ------- 140 / 0.059
Old Mar 6, 2004 | 03:58 AM
Pistonman's Avatar
Zero, I just got the pipe, D.J. kit, twist throttle,IMS parts, AC parts this week (mail order) --still waiting for the DG snorkle. Have not started putting together yet, will post any results. Between work and trying to remodel house very little wrench time during the week. Try to get parts ordered, do research during the week so I don't have to do it on the w/end.(wrench time)
speedbuff
13
Nov 11, 2020 10:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
rgjackson
Sep 17, 2015 11:21 AM
awer1968
Sep 8, 2015 11:02 AM
