300ex problem
Old Mar 6, 2004 | 09:44 AM
swampy's Avatar
Default 300ex problem
My brother has a 98 300ex and it cuts out and revs for a second then cuts out again. It has a new spark plug, carb is clean. I think the oltage regulator is bad because when it will run if you turn on the headlights is instantly dies. Also it doesn't charge the battery. Keep in mind that it does this quite often and is almost unrideable, however sometimes it will run ok but eventually starts acting up. Any help before he spend a fortune replacing parts.
Old Mar 6, 2004 | 09:54 AM
WISTECH's Avatar
Check your pm well get you going again
Old Apr 17, 2004 | 05:08 PM
swampy's Avatar
well an update. I bought a new voltage regulator and it fired straight up and run perfect for about 2 weeks then it's back to doing the same thing again any ideas?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
