easy pull clutch
Old Mar 10, 2004 | 09:42 PM
emac's Avatar
Default easy pull clutch
hey, i have a 400ex and the clutch is wiked hard to pull, after long rides i get arm pump and it gets harder and harder for me to pull the clutch in. rite now i have a fly clutch assembly. any of you have any easy pull clutch assemblies or that moose setup thing, i like the hydralic but its outa my price range. if youv had any luck or got suggestions for easy pull setups let me know. thanx
Old Mar 11, 2004 | 04:42 PM
kakaboogie's Avatar
if u go to exriders.com there is a tech artical of one thats really nice and easy to pull
btw... i am thinking about buying a 400ex, is it a nice bike for someone who has little clutch experiance? right now i have a ozark and a kodial 450
Old Mar 11, 2004 | 05:45 PM
emac's Avatar
kakaboogie, the 400ex is about the same as most other manual sport quads, but when my freind first got his 300ex and learned to use the clutch he couldnt use mine, dont no y but he couldnt. even if it is a little hard at first u gotta learn sometime right? and the 400exs are great bikes
Old Mar 11, 2004 | 07:26 PM
whatwasthat's Avatar
Before you go spending cash on a new clutch perch, try lubing the cable, or buying a new one, most of the time, the cables get overlooked, but should be regularly lubed too.
Old Mar 11, 2004 | 07:42 PM
emac's Avatar
thanx watwasthat but i already libed, then replaced the cable
Old Mar 11, 2004 | 07:47 PM
Are you running aftermarket clutch springs? Otherwise, if you have a new cable with stock springs, something is out of adjustment.
I was running a stock perch with ebc springs and was a very easy pull, but have since upgraded to a pep easy pull perch setup. Pull is slightly less with the new perch.
Old Mar 12, 2004 | 03:54 AM
cals400ex's Avatar
if you have a new cable, i would consider an rtc lever. i hear the pull on that is the best you will find. however, the lever isn't cheap.
Old Mar 12, 2004 | 11:19 PM
emac's Avatar
watwasthat, i have a completely stock clutch and i have a new motion pro cable, the lever has been hard to pull ever since i switched from the stock assembly to my new fly easy adjust
ghost civic
Jan 15, 2020 07:43 AM
robert301972robert
Aug 30, 2015 11:34 AM
ghost civic
Jul 15, 2015 10:48 PM
brad wheeler
Jul 13, 2015 11:19 PM
200es
Jul 10, 2015 09:09 AM
