Tether cord help on Pred
Old Mar 13, 2004 | 06:05 PM
Bradracer18's Avatar
Default Tether cord help on Pred
Hey guys, I have a question about my pred. I bought a tether cord today, and I was wondering how to install it. Can anyone help?? Thanks Brad
Old Mar 13, 2004 | 06:48 PM
GE4x4's Avatar
If it's a Polaris tether, there is a plug right below you lights. Plug the tether into it. Then drill out the flat round area by your dummy lights, then install. If it's another type, like Pro Design, you can make up a end that will plug into the stock plug, then mount to handle bars.
Old Mar 14, 2004 | 12:01 AM
WFOPredator's Avatar
What I did with my "other than Polaris" teather was just to flatten the terminals that came on the unit and slid them into the plug on the quad. They haven't fallen out, but to be on the safe side I also wrapped the entire thing up with some electrical tape.
Old Mar 14, 2004 | 12:13 AM
Hozed's Avatar
i did the same.. but for some reason it doesnt work anymore... i htink it just came loose...
i hate the polaris type teather... they are junk.
Old Mar 14, 2004 | 12:55 AM
no place to mount the Polaris one with the trailtech logo bar clamp! lol
Old Mar 14, 2004 | 02:58 AM
Maddog419's Avatar
Yea right.
Try putting it in right.
later
Old Mar 14, 2004 | 10:32 PM
modquad's Avatar
The Pure Polaris unit mounts easily. I drilled a hole on the flat on the RH fender. The plug is normally behind the RH headlight. Make sure to take time mounting it so you get proper engagement. :0
Old Mar 14, 2004 | 11:00 PM
Hozed's Avatar
Originally posted by: Maddog419
hate the polaris type teather... they are junk. Yea right.Try putting it in right...later
not quite sure what your saying here... but i am talkin about the difference between the clip and plug type teathers.
the clip is 100 x's better... no arguement needed.... thats the bottom line.
Old Mar 15, 2004 | 01:37 PM
Thanks for all of the info guys, I have a "Gunnar Killer" tether. It comes with a ground wire( a hole in it) and a male plug end and a female plug end. The actual switch is to be put on the handle bars, where do you guys suggest putting that?? There doesn't seem to be much room or anywhere handy. So I assume that I put the ground into a bolt near the steering stem or somewhere like that, probably doesn't really matter as long as it goes to the frame. So where do the plugs go?? I'm not even sure what the whole Pred electrical system looks like, or even how to access it. Thanks for everything. Brad
SDR-II
Sep 29, 2015 01:06 AM
BYC
Sep 25, 2015 02:10 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
MOJAVE02
Apr 1, 2002 11:00 AM
