200x
Old Aug 30, 1999 | 03:03 AM
Frankie's Avatar
I have a 200x. It just recently quit on me. Before it quit, it had white smoke coming out of the exhaust and the was oil leaking out somewhere by the head. The spark plug was black the last time I changed it. Now it won't start and when I push down on the kickstart, it feel as if I don't have any compression. What is wrong? I don't know much about motors, but I think the piston rings are bad and the head gasket is bad. I think I should get a new piston, rings, and a head gasket and have the cylinder polished or whatever that is called. What do you guys think I should do?Or possible have it bored out. How much might that be?
Thanks
Old Aug 31, 1999 | 12:19 AM
bigmanMH's Avatar
I would think that your head gasket is bad and you are loosing compression throught this gasket. your engine will not run with the proper compression level. You will not have to get your engine board out but you might need to get a few new parts but that is common.
Old Aug 31, 1999 | 10:34 PM
Frankie's Avatar
Thanks for the reply. I finally tore the top of the engine off and looked at the piston and valves. They were all covered with a real thick carbon sludge probably from burning oil. I think I might have it bored out anyway cause I need some more power. What could I bore it out to? I would say .40
Old Aug 31, 1999 | 11:11 PM
bigmanMH's Avatar
I have a 200es. about 197cc. you would probable be able to get yours board out to 292cc
Old Aug 31, 1999 | 11:13 PM
bigmanMH's Avatar
frankie i need to know how to get the top of my engine off could you email me at
hhartke@xel.net thanks bigman
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
88Warrior
ATC 3-Wheelers
Aug 7, 2001 07:27 PM
hrc200x
ATC 3-Wheelers
Feb 7, 2001 08:46 PM
bigmanm
Jun 28, 2000 10:34 PM
200X
ATC 3-Wheelers
May 24, 2000 10:47 PM
