Can Dynojets be installed with aftermarket cams?
Old Mar 14, 2004 | 10:08 PM
LittleBoy's Avatar
Default Can Dynojets be installed with aftermarket cams?
I had good results with Dynojets vs stock jets and needles with stock cams. After a cam change and four different trials with two different technicians, I get better results out of my aftermarket cams with the stock needles and jets than the dynojet kit. Aren't dynojets suppose to give better results even after changing your cams for more agressive ones?
Old Mar 15, 2004 | 04:31 AM
cartman308's Avatar
changing cams will change you valve timing. Changing valve timing will effect the amount of air and fuel going into the cylinder. When you change cams you need to change jets to match the new vavle timing.
Old Mar 15, 2004 | 07:30 AM
LittleBoy's Avatar
It has been rejetted, but on four trials we still had better results with the stock jet/needle set-up vs Dynojet
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
