lakota valves
Old Jul 13, 2000 | 01:02 AM
Sandman75's Avatar
still having valve problems, can anybody tell me the correct way to adjust these @#!$ing things! its driving me insane! thx sandman
Old Jul 13, 2000 | 03:13 AM
Tree Farmer's Avatar
Armyman posted a terrific procedure for adjusting Bayou valves; the Bayou and Lakota engines are extremely similar; E-mail me if you want a copy and I'll forward your request to Armyman.
Summarized, find TDC on compression stroke (timing marks & index, or remove spark plug, pull engine through with starter rope until air rushes from hole, piece of wire indicates piston at top). FYI: Intake and exhaust valves of all 4-stroke engines are totally closed at TDC on compression stroke. Remove valve caps (8mm wrench), insert feeler gauge (.004 or thereabouts) between valve stem & rocker. If too tight or too loose, loosen 10 mm lock nut and adjust screw to set proper clearance. Hold screw position when clearance is achieved and tighten lock nut; recheck clearance. If o.k., button up and dig out.
What, exactly, is your problem?
You probably have to remove your fuel tank to reach the front valve conveniently. Do you have a service manual?
Tree Farmer
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
