PIPES FOR LT80
FMF and DG both make pipes along with a few others. I bought a FMF for about $185. The DG is a little cheaper while the others are a little more. Alot of guys that race run the stock pipe thats been modded. Alot of online places sell both of these pipes, such as rockymountain, dennis kirk, etc...
The best pipe is the stock pipe in stock form. I suspect you are wanting more noise than power/speed (you get power/speed from the motor not a pipe) then get a DG pipe. They are cheap enough. The FMF is a good pipe for a stock machine, but once the motor is modded the FMF is useless. I don't recommend that pipe at all.
After riding the stock LT80 for three years in the yard I decided to put some upgrades into Andrews atv. I've added the FMF Pipe for about $200 including silencer & a Boyesen dual power reed and a new set of stock rings. I did the test ride and some tuning. Then it was Andrews turn. His eyes opened up like ping pong ***** the first time he hit the gas. It was great to see. The pipe makes a difference. A stock pipe does not put out the same torque as the FMF .
