Is there such a thing as a "bored" carb?
Old Jul 13, 2000 | 10:47 PM
Holyman's Avatar
The guy I bought my Banshee from said the carbs were bored out. I said do you mean the cylinders, he said no the carbs. Has anyone ever heard of this? He said he had it done the same time he had Toomey pipes and a twist throttle put on it. He also had the carbs re-jetted the same time. He also said he had "carbon fiber"? reeds installed. I'm mainly interested in what he meant by by "bored" carbs.
Old Jul 13, 2000 | 10:56 PM
Rocky's Avatar
you bore out the intake side of the carb increasing the size of it commly done in race apps. I have 28 Kehins bored to 30mm
Old Jul 13, 2000 | 11:02 PM
Tree Farmer's Avatar
Yes, Holyman, some carbs can be overbored to increase airflow/reduce restriction.
The main difference in, say a 32 mm vs. a 34 mm factory carb by one manufacturer may be the bore diameter; sometimes the external castings are identical.
If your seller had the carbs bored carefully by someone who knew what he was doing, the system can handle more intake volume with less restriction than the stock setup.
Tree Farmer
Old Jul 14, 2000 | 09:10 AM
cstark's Avatar
Instead of spending $400 dollars on a new carb. I spent $50 bucks and had my 32mm carb bored to 34mm. Haven't had a carb problem yet (knock on wood).....
Chris 00' TC Racing 300EX
Old Jul 14, 2000 | 01:03 PM
Mike300EX-99's Avatar
Chris, who bored your carb? Thanks, Mike.
Old Jul 14, 2000 | 02:53 PM
Holyman's Avatar
Thanks for the info. He also said he changed the carb tops. Is this a typical thing to do when you bore the carb? I would like to convert back to thumb throttle when I get it up and running again (my friend crashed it) but the guy I bought it from said I would have to change all of the cables. That doesn't sound necessary. I lost his phone number after I bought it and his number is unlisted so I can't ask him directly. I appreciate all of your help.
Old Jul 14, 2000 | 03:05 PM
cstark's Avatar
I know that when you buy a twist throttle, you get the whole assembly. So there must be some differances in the cabling between thumb and twist throttle cables. I don't know what they are, but I know that they are indeed different.
Carb boring..... My dealer bored the carb the extra 2mm for me. I don't know what kind of tooling it takes or how they do it. I paid $50 dollars for the boring, 350X breather boot, and larger main-jet. Not a bad price.
(if you are interested, I can contact my dealer and ask what the carb boring all intails)
Old Jul 14, 2000 | 07:09 PM
Suzuki03's Avatar
You will need new cables to convert back to thumb throttle.
Old Jul 15, 2000 | 11:22 AM
Holyman's Avatar
Suzuki3 will I have to change all of the cables of just the upper one? I would think that there is a way to just replace the upper cable without replaceing the lower 2 as well. Do you know where I can get these cables?
Old Jul 15, 2000 | 12:23 PM
Suzuki03's Avatar
Im pretty sure that when you buy a twist throttle for a banshee that you have to buy everything, so I would think so.
JBibb
Jul 4, 2015 10:16 AM
Shawn_z400
Jul 1, 2015 03:37 PM
robj
Jun 15, 2015 08:45 PM
Berjr
Jun 15, 2015 04:41 PM
Joe04785
Jun 15, 2015 03:12 AM
