battery trouble?
Old Mar 20, 2004 | 11:19 PM
predator500rider's Avatar
Default battery trouble?
does anyone have any trouble with the 03 predator battery?!??! i keep losing power!!!![img]i/expressions/face-icon-small-frown.gif[/img]
Old Mar 20, 2004 | 11:30 PM
trailrider500's Avatar
I hear of that a lot.. Many have found out that the pred's charging system wont charge a dead or near dead battery...
Some don't leave their battery outside when its cold...
Old Mar 21, 2004 | 08:46 PM
predatordude's Avatar
It has a sealed battery, these batteries need to be charged frequently if not used. It your quad sits for more than a couple of weeks i'd check the voltage, if it gets below 12.8V, be sure to charge it up.
Old Mar 21, 2004 | 09:27 PM
im not talking about the charge i mean like some kind of lose connection when i hit a bump the wrong way it will shut off and ill have no power but i checked the wires and i cant see anything
Old Mar 21, 2004 | 10:29 PM
powerslider's Avatar
Check the circuit breaker, it's in a black plastic pouch right above the coil under the left black plastic trim panel. Water intrusion can damage/corrode the internals causing the intermittent power loss...
Old Mar 22, 2004 | 01:50 AM
hondabuster's Avatar
Im getting the impression this has happened more than once.
Howd you get the power back? A new battery? Charging? Smackin the battery around?
If its the same battery, id say its an internal defect. Could be a loose plate, or bad solder job. When it dies, have a voltmeter handy, You can get one at harbor frieght for 5 bucks, and check the voltage accross the terminals, if its under 10 volts, its junk.
If it isnt the same battery, then it could be the battery mount is loose and the battery bounces around and breaks up inside.
Old Mar 22, 2004 | 06:08 PM
fidge1's Avatar
Mine did the same thing and the problem was that the negative connection kept loosening up when i was riding-- I changed the bolt and tightened it good and have not had a problem since
Old Mar 22, 2004 | 06:56 PM
nccracing's Avatar
I had the same problem a Fidge .
Hunter100us
Oct 7, 2015 11:46 PM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
house1
Aug 9, 2015 10:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
