Attention! Question about Superwinch switch!
Old Jul 15, 2000 | 09:07 PM
SuperDuty335's Avatar
I finally wound up going to K-mart and buying a Superwinch T1500 a few minutes ago. They only had one and it was opened. I checked everything and it was there, so I bought it and got 10% off. I got home and found the instructions were gone and part of the switch was gone. Are there two parts to the switch? I need the wiring instructions also.
Old Jul 16, 2000 | 03:17 AM
Tree Farmer's Avatar
Don't know what "vintage" T1500 you got; there have been changes with the rocker switch assembly recently--you DO have a rocker switch, right?
For technical information on your parts, contact jack@superwinch.com or telephone Superwinch technical service ((860) 928-7787) and ask for Jack Jolly.
Wiring is pretty simple, with a VOM, you can find the right contacts. The switch has four terminals, battery +, battery -, winch "A," and winch "B." The Battery + and - wires go into the switch; the outgoing connections to the winch motor reverse when the switch is moved to the "Out" or "In" positions. When the switch is at rest, or "Off," a shunt (dead short) is applied across the outgoing terminals (for dynamic winch motor braking). When "Off," the positive battery connection does not contact any other terminal; this may be true for the battery negative terminal also.
With an ohm-meter, find the two contacts electrically connected when the switch is in the "Off" position, these two go to the winch motor. Find a terminal that connects to no other terminal when in the "Off" position; you may use that one as the battery positive terminal; the remaining terminal is battery ground. Switch connections to the winch motor around to obtain proper "Out" and "In" rotation if necessary. Good luck!
Tree Farmer
Hondapolaris8596
Jul 28, 2016 03:17 PM
user493
Aug 13, 2015 12:54 PM
black_thunder
Jul 28, 2015 11:05 PM
jayking232003
Jul 23, 2015 05:48 PM
cornermike
Jul 8, 2015 11:44 PM
