no muffler ?
Old Mar 26, 2004 | 01:26 AM
4x4eva's Avatar
Default no muffler ?
Hi, I have a stock 350 4-stroke and was wondering if it would wreck the engine if i took of the muffler but left the stalk pipe. Thanks
Old Mar 26, 2004 | 01:33 AM
trailrider500's Avatar
If you take the muffler off and run it out of the header, yes kiss your valves good by... You need some back pressure for the engine to run correctly and safely...
TrailRider
Old Mar 26, 2004 | 12:55 PM
Doctorturbo's Avatar
GOT BOOST!
You can safely run your quad without having a muff on it. You won't wreck anything. The only problem MIGHT be if you get the pipe too short you can suck cold air on reversion and that is not good for the exhaust valve. But I'm talking REAL short pipe here. I can only assume that you are going to just take the muff off and leave the head pipe on. If so, you will be fine.
Old Mar 26, 2004 | 10:42 PM
moldycheese's Avatar
you would also have to re jet so u dont leen burn ur engine
Old Apr 16, 2004 | 12:15 AM
atc110rider's Avatar
you propbly wont have to rejet and nothing bad will happen
thats just an old wives tale
Old Apr 16, 2004 | 07:48 PM
warrior387cc's Avatar
ive seen the exaust valve burn before because of no muff bad idea you could just gut
the old one slightly
Old Apr 16, 2004 | 07:55 PM
that is not an old wives tale. if you dont re-jet, ur burn will get realy hot, and that is what warps your valves.
Old Jun 19, 2004 | 02:24 AM
trex200's Avatar
I dont recommend taking off the muffler. removing the muffler will help power in midrange, but it will not improve bottom end by much. not enough back pressure. another risk of removing the muffler is burning the exhaust valve up. the entire exhaust system acts as a heat conducter. by removing the muffler you are shotening it so that alot of heat is trapped in the exhaust tract this will burn the exhaust valve it doesnt allways happen. if you still want it loud and get the power in the midrange remove your mufflers internal components and then bolt it back on at least this way you still have it as a heat conducter.
Old Jun 19, 2004 | 02:25 AM
trex200's Avatar
shortening***
Old Jun 19, 2004 | 08:57 PM
hondaguy13's Avatar
i have heard that it will bend the vavles
exmotocrosser
Sep 13, 2019 06:12 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
slowgsxr97
Sep 8, 2015 07:33 PM
