bogging blaster
Old Mar 28, 2004 | 02:24 AM
iwannabfast's Avatar
Default bogging blaster
hey guys i was just getting some imfo for a friend on a blaster i think its mid nineties it has purple plastic if that tells you anything about it anyway he just bought this thing and it is really bogging out bad it sounds like a four stroke it has a k&n air filter and problably has been rejetted i think he said the main # was 230 sorry if im wrong but anyway he cleaned the carb and the air filter and the plug what else could be causing this? there are a couple vent hoses missing on the carb would that be the problem? does anyone know how many turns the screws on the carb are supposed to be turned
thanks for your help we really appreciate it
Old Mar 28, 2004 | 03:23 AM
raptor8's Avatar
man that could be a lot of things really. check the plug.. it's prob wet and fouled. make sure the air filter is clean.. a new plug will prob help. what kinda carb on it? what kinda pipe? I think 230 is close to stock jet size.. i run a 310 with my toomey pipe. sounds rich, but the TORS could be messing with you... that box on top of the carb, if it has the stocker carb. there's a way to bypass it, but i'm afraid I dont know how. It involves one of the boxes under the hood tho. Ive never had any trouble with it.
Check the simple stuff cuz that's what it will be.
you'll find it.
Old Mar 28, 2004 | 10:45 AM
could i change the needle clip position i think that might help so i move the clip up or down to make it run leaner i think its up not sure though
Old Mar 28, 2004 | 02:07 PM
lapeerbanshee's Avatar
i agree with raptor8 try to put in a new plug
Old Mar 28, 2004 | 02:12 PM
Yfz450VsBanshee's Avatar
My friends blaster did the same thing. He put a block off kit on it changed the plug rejetted it. It didnt bog anymore after that.
Old Mar 28, 2004 | 09:00 PM
Criminalpoet's Avatar
The needle clip position controls from 1/4 to 3/4 throttle, the main jet takes over from 3/4 to full throttle, and the pilot jet controls from idle to 1/8 throttle so as you can see each jet controls the air fuel mixture delivery at certain points of the throttle position.. To determine what needs to be adjusted you must first do plug chops at all of the different throttle positions. The airscrew should be no more than 2 turns out and no more than 1 turn in.. The ideal setting for the airscrew should be between 1-2 turns out... Change the plug first and if thats not the problem do a compression check. If the compression is 125psi or lower you should consider a top end rebuild. But if the compression is not low then your problem is most likely jetting...
A friend in the Blasters, Jose
Old Mar 28, 2004 | 09:48 PM
wanaply21's Avatar
do u turn the air jet 2 turns out from being all the way in or what?
Old Mar 28, 2004 | 09:50 PM
Shav0's Avatar
never tighten the screw in all the way or it will stip them real easy.
you only turn them out as much as you need them, it will be different on every bike.
Old Mar 29, 2004 | 10:36 PM
raptor8's Avatar
be gentle on the jet screws! try starting at 1.5 turns from closed. i think the stock needle position is right in the middle, and yes, moving the clip will make a huge diff, cuz that controls where you do most of your riding. I know I had to move the clip down one with the toomey pipe, to raise the needle and it works perfectly. are we dealing with a stock muffler? that will make a huge difference. keep an eye on the plug and dont overtighten that either...the color will tell you what is happening. just tinker with it, youll find the right combo.
the rig could be worn out too ya know... a compression test will tell. you can use a car compression tester and youll know right away....could save you a lot of time.....[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 29, 2004 | 11:15 PM
ok boys i appreciate the help we took it by a friends house today that knows alot about 2 strokes he said that he thinks the crank seals are going out and its letting air in that would explain the problem at high rev bogging, has anyone had this problem and if so where is the best place to get them and is it hard to fix we do a little work on my scrambler but we have never tore into a blaster
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
