NO START GRIZZLY, NEED HELP
I was out riding with the family when my wifes 2000 grizzly 600 died, it would restart but as soon as you hit that throttle is died. finally after several attempts it just would not start at all, I towed it back to the camp site and did a preliminary assesment. The spark plug wire was realy hot. and There wasnt any spark at all. I swapped out my sons coil just to see whether or not the coil may have failed. but nothing changed. How would I determine if I lost a CDI or a Stator.
any help you can give would be great
Thanks
Thanks
I did that and there wasnt any spark, I swapped coils from my sons machine and still no spark, How would I go about testing the stator or the CDI to verify fault in those areas
Here are some areas to look into. If you need procedures to check any item post back and we will try to help.
ELECTRICAL SYSTEM
Spark plug
Improper plug gap
Worn electrodes
Wire between terminals broken
Improper heat range
Faulty spark plug cap
Ignition coil
Broken or shorted primary/secondary
Faulty spark plug lead
Broken body
CDI system
Faulty CDI unit
Faulty pickup coil
Faulty charging/rotor rotation direction coil
Broken woodruff key
Switches and wiring
Faulty main switch
Faulty engine stop switch
Broken or shorted wiring
Faulty gear position switch
Faulty start switch
Faulty rear brake switch
ELECTRICAL SYSTEM
Spark plug
Improper plug gap
Worn electrodes
Improper heat range
Ignition coil
Broken body
CDI system
Faulty CDI unit
Faulty pickup coil
Broken woodruff key
Switches and wiring
Faulty main switch
Faulty start switch
