NO START GRIZZLY, NEED HELP
Old Mar 30, 2004 | 08:29 AM
YFZRYDER's Avatar
Default NO START GRIZZLY, NEED HELP
I was out riding with the family when my wifes 2000 grizzly 600 died, it would restart but as soon as you hit that throttle is died. finally after several attempts it just would not start at all, I towed it back to the camp site and did a preliminary assesment. The spark plug wire was realy hot. and There wasnt any spark at all. I swapped out my sons coil just to see whether or not the coil may have failed. but nothing changed. How would I determine if I lost a CDI or a Stator.
any help you can give would be great
Thanks
Old Mar 30, 2004 | 09:33 AM
Sparky660's Avatar
I would check for spark first if your worried about thte cdi. Take a old plug if you have a spare and crankk the engine over. You should see an intense blue spark jump the gap.
Old Mar 30, 2004 | 01:52 PM
YFZRYDER's Avatar
I did that and there wasnt any spark, I swapped coils from my sons machine and still no spark, How would I go about testing the stator or the CDI to verify fault in those areas
Old Apr 1, 2004 | 09:52 PM
Vakero's Avatar
Here are some areas to look into. If you need procedures to check any item post back and we will try to help.
ELECTRICAL SYSTEM
Spark plug
 Improper plug gap
 Worn electrodes
 Wire between terminals broken
 Improper heat range
 Faulty spark plug cap
Ignition coil
 Broken or shorted primary/secondary
 Faulty spark plug lead
 Broken body
CDI system
 Faulty CDI unit
 Faulty pickup coil
 Faulty charging/rotor rotation direction coil
 Broken woodruff key
Switches and wiring
 Faulty main switch
 Faulty engine stop switch
 Broken or shorted wiring
 Faulty gear position switch
 Faulty start switch
 Faulty rear brake switch
TLC
Jul 1, 2015 08:29 AM
RPK
Jun 8, 2015 01:05 AM
atvdave
Jun 4, 2015 06:06 PM
1000gade
May 27, 2015 12:37 PM
Undecided350
Jan 15, 2001 03:55 AM
