Will a slide and needle not moven cause banshee to pop?
My 2002 banshee the left carb choke side. When i give it gas the slide and needle dosent move on that carb. The right side does, but it shoots flames kinda.I was wondering what to do to fix it? Or how to adjsut the slide on the left. And if that will caust to run crappy?..
charlie
charlie
Im not sure where to check on the cable. But the slide dosent fit all the way down to the bottom of the carb like the right side. But are the two carbs diffrent for secondary and primary i wonder?.. But the left needle and slide dosent move at all ever throught the whole thorttle..
I'll bet it's not the cable. Are you sure the slide is falling all the way down into the carb when you assemble it?
There is a groove...if the slide is twisted a bit on install it will never fall all the way down in the carb.
Yes i adjsuted the needle clip. up one notch it braught the sldie down a lot more. But now it idels way to high. How can i adjsut the idle on it?..
speedbuff
13
Nov 11, 2020 10:16 AM
