Will a slide and needle not moven cause banshee to pop?
Old Mar 30, 2004 | 03:27 PM
Chazzman's Avatar
Default Will a slide and needle not moven cause banshee to pop?
My 2002 banshee the left carb choke side. When i give it gas the slide and needle dosent move on that carb. The right side does, but it shoots flames kinda.I was wondering what to do to fix it? Or how to adjsut the slide on the left. And if that will caust to run crappy?..
charlie
Old Mar 30, 2004 | 03:29 PM
Shav0's Avatar
your needle should move on both carbs.
is the cable ok that leads to the carb that isnt moving? or is it the needle itself.
Old Mar 30, 2004 | 03:41 PM
Chazzman's Avatar
Im not sure where to check on the cable. But the slide dosent fit all the way down to the bottom of the carb like the right side. But are the two carbs diffrent for secondary and primary i wonder?.. But the left needle and slide dosent move at all ever throught the whole thorttle..
Old Mar 30, 2004 | 03:43 PM
Shav0's Avatar
take it off and find out why.
it might be siezed in there from somthing or the cable might not even be attached.
Old Mar 30, 2004 | 04:04 PM
Chazzman's Avatar
Well i tore it apart to clean it. So i knoo it wasnt seized.. Is there a way to adjsut the cable or something?...
Old Mar 31, 2004 | 01:04 PM
Shav0's Avatar
yea, there is
but im not familiar with the banshee's cable set up.
Old Mar 31, 2004 | 03:42 PM
sAyIt_fmf's Avatar
I'll bet it's not the cable. Are you sure the slide is falling all the way down into the carb when you assemble it?
There is a groove...if the slide is twisted a bit on install it will never fall all the way down in the carb.
Old Mar 31, 2004 | 03:49 PM
Chazzman's Avatar
Yes i adjsuted the needle clip. up one notch it braught the sldie down a lot more. But now it idels way to high. How can i adjsut the idle on it?..
Old Mar 31, 2004 | 05:35 PM
Banshee2003's Avatar
Are you sure the Needle is going into the hole in the bottom of the carb? The needle will have play and unless you guide it in could miss the hole.
Old Mar 31, 2004 | 06:14 PM
Shav0's Avatar
If you still have the TORS system on your bike then the idle screw should be on that. Turn it out to lower the idle.
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
